Old 08-25-2017, 09:59 PM
Originally Posted by YellowGT View Post
It only goes on til it stops.
Well.... yeah. But it's a screw on cap is it not? Threaded cap. Not a 1/4 turn cap correct? So, you screw it on until it stops, then make it tight. Just like putting a lid on a bottle of soda pop. Even in the crankcase pressured up too much, it would blow the seals out before it blew that cap off.... unless you didn't put it on tight and it unscrewed then vibrated loose until it popped off. That or you didn't reinstall it at all, and took off not knowing it, only later to discover it missing. Believe me, if you had a crankcase pressure issue, it would be doing a lot more bad stuff besides randomly losing the oil fill cap 1 time a year. Like I said..... I bet you either didn't reinstall it after topping off the oil, or it came loose. Happened to me before, so don't think I'm making fun. It happens.
Old 08-27-2017, 02:38 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Or the first guy stripped the threads with his 48" pipe wrench
1- 1200 in pieces
1- 1864 in pieces
Old 08-27-2017, 03:05 PM
Old 08-28-2017, 10:36 AM
YellowGT YellowGT is offline
No, it's a 1/4 turn cap.
Old 08-29-2017, 11:49 AM
PaulS's Avatar
PaulS PaulS is offline
If it is a 1/4 turn cap then your 20 horse command is a late model command. The CH 20 originals have a screw on cap that you can tighten down. I have an original ch20s in a 2084 and never had your problem.
Old 08-29-2017, 08:32 PM
It turns a quarter turn, or it's a quarter turn cap?
A quarter turn cap would have two tangs on it. If it has threads, it's a threaded cap.... that apparently turns a quarter turn to tighten. Two very different things.
If it is a true 1/4 turn cap, I want the model number of the engine, because I've not seen one with a 1/4 turn cap.
Old 08-29-2017, 08:58 PM
CubDieselFan's Avatar
A picture can tell a thousand words or posts.
Old 08-30-2017, 07:44 AM
Here is a 1/4 turn cap. CH22, this one is in my 1864/2264
Old 08-30-2017, 07:59 AM
There we go.
To be fair, that is a new motor..... not a Cub Cadet spec''d motor. And a 22hp, not 20.
Old 08-30-2017, 10:16 AM
Baccarat Baccarat is offline
When you lost the original one last summer and replaced it, could the dealer accidentally have sold you the wrong style? A 1/4 turn instead of a screw on? Or, vice/versa. Or perhaps the part box/bag was mislabeled?
Things happen.
