Old 08-05-2017, 10:31 AM
You may need to add some support on the outside of the seat, you may find that the plastic decking is a bit flimsy where it's not supported.
I started to have end supports,,
then decided to make the table short, or, not much overhang.
Total table length will be 5 feet or less.
Does the plastic wood get hotter than regular wood?
Old 08-05-2017, 10:33 AM
scarps68's Avatar
scarps68 scarps68 is offline
Some PVC decking does get hotter than wood. Also keep in mind some brands (Azek) had issues fading rather quickly. I'm not sure which brand you're thinking of using.
Don
882D
50" Deck Mower
54" Snow Dozer Blade
Agri-Fab Lawn Sweep
Old 08-05-2017, 10:47 AM
A local lumber yard closed, I bought some boards,, when I was building bluebird houses at the time,,
The yard only carried the best (probably why they went out of business??)
so, we will find out if it fades.
I only paid about 1/2 what regular wood cost,, Hmmmmm,,
Old 08-05-2017, 09:07 PM
The bolts came in the mail today,,,
Luckily, I could back the trailer in the shed, and work on the table.
Shade was really welcome today,,,
Now,, I gotta see if I have enough material to build my daughter a garden picnic table.
At first glance, the table seems too high, but, then the height starts to grow on you.
It is a convenient height to use whether you are sitting,, or standing.
The bench is 22" off the ground.
Old 08-05-2017, 09:37 PM
How are you going to drive the tractor and sit on the table @ the same time?
or is it equipped with auto steer?
Old 08-05-2017, 09:41 PM
I will let the grandchildren haul me around!!
