Old 05-21-2017, 03:03 PM
We had schedule 40 pvc pipe in the shop for the longest time and never really had an issue, we switched to black iron when we got the big screw compressor's.
Old 05-21-2017, 03:24 PM
Dirty Steve's Avatar
My brothers used the Rapid Air Fast pipe system in their shop. They hooked the air compressor in with a hydraulic hose also. Electrician had them power the compressor of one of the main light switches. Sometimes shops burn down when compressors run wild. Most folks turn the lights off was the protective theory.
Old 05-21-2017, 05:46 PM
john hall's Avatar
We have black iron pipe here in the farm shop, no problems after 35 years. At work we have really heavy wall plastic--could be PVC, CPVC-I don't really know. Its 22 years old and we have had a few blowouts over the years. Its pretty easy to splice into it when we need to make repairs or add/rearrange equipment. Boss was looking into replacing it all with some sort of aluminum, don't know why he didn't follow through. FWIW, we run 100-105 psi at work, at the farm shop its about 140--wherever the compressor cuts off at. Oh yeah, at shop the lines are steel in the compressor house, we switch to plastic once they are inside the shop, past the regulator. Early on the plastic didn't like the heat and cold in the compressor house is why we made the switch.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-21-2017, 07:00 PM
I used 5/8" OD Copper Tubing 20+ yrs ago and still going strong.
Old 05-21-2017, 08:15 PM
looking to set up my garage, I think I want to use 3/4" copper with 1/2" drops..... also looking into an air drier to plumb inline with it too.
