Old 02-05-2017, 04:18 PM
tinkerman tinkerman is offline
Just doin a little cleaning and sorting while waiting on block and parts and paint and...... ok question for someone... I took the steering gear box apart so I could clean it up. Gonna order new ball bearings and keepers, maybe side plate/ gasket. On the steering end of the shaft, looks like their should be a bearing? Am I correct? Austin parted everything up in bags, but didn't label the bags. I've caught myself a time or two saying why didn't you label this, then I hear his answer in my head... "why didn't you"? So..... anyway here's some pictures of the progress
Old 02-05-2017, 04:56 PM
johncub7172's Avatar
Thumbs up
I'm in to help when and where I can! Glad you decided on the model 102. They are a great garden tractor!!!
I'd like to suggest a 606 nice bearing in there? Maybe other more knowledgeable members can chime in on that claim. I'd also suggest, when you get that far, to check the front axle for any horizontal play between the frame's c-channel when turning left and right. Squeeze it together, then assemble. I have a nice wright up on the the detail, on my model 71, here at OCC.
I'll be in the bleachers rooting you on!
Take care,
John
Old 02-05-2017, 05:31 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Glad you are undertaking this project, the 102 is a great tractor. Especially with the history yours has. What part of tn are you from? I'm frequently in East Tennessee
-Rick
IH 782
IH 126
CCC 1863
Old 02-05-2017, 06:32 PM
About 40 miles west of nashville
Old 02-05-2017, 06:48 PM
Rmowl's Avatar
Right on, did a job out at land between the lakes near Clarksville couple years ago
-Rick
IH 782
IH 126
CCC 1863
Old 02-05-2017, 08:24 PM
mortten mortten is offline
If you're talking about the steering wheel end there is a little plastic bushing. You can use an old (or new) wheel bearing instead.
Doug
QA-36A
42" blade
Old 02-05-2017, 09:04 PM
Yes, there's a metal collar on the steering end. Looks like something should be there to keep the steering shaft centered in the sleeve. Or maybe the steering wheel does this?
Old 02-06-2017, 07:31 PM
Ok , I've got a few more questions. First back to the steering box. The thin plate on the side that has the lip on it, I'm assuming the lip goes into the housing, with the gasket between the bottom of the thin flange and the housing, right? Then the thick plate with the cam on it just rides on top of the thin flange? If I'm right so far, here's what I'm thinking, poor design!! Could I replace the gasket with a bead of aluminum silicone. This would last forever and keep the thin flange in place permanently. (And save $100). I got the thin piece flattened out really well but don't have the gasket. Now next question, I'm looking at the clutch and posted pics. I'm thinking new disc (discs) and throw out bearing? Can you tell from pics if I'm correct? I was trying to get the driveshaft off the differential and looks like pins thru the shaft holding it on, but dang I'm not having any luck at all pecking them out. Any advice would be appreciated
Old 02-06-2017, 08:30 PM
RedHawCadet RedHawCadet is offline
I believe this is the bushing your talking about.
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 02-06-2017, 08:39 PM
The clutch disc is toast, might as well replace the disc and throw out bearing and have the pressure plates resurfaced. You will probably never have to do it again.
Mark
QA42 snow thrower
42in front blade
