Old 01-25-2017, 07:39 PM
RLause's Avatar
RLause RLause is offline
I had one like yours, bent the tab and it worked great. I think when the part is heat treated, they try to keep the hardness in the wear area. I'm glad it worked out for you.
Richard
Old 01-25-2017, 08:50 PM
REDDHOGG REDDHOGG is offline
Mr Bob. Glad you found the problem ,wouldn't hurt to check valve lash also .if it is way out the valve will not open on the a.c.r.
Old 01-25-2017, 09:14 PM
john hall's Avatar
Originally Posted by Mr Bob View Post
Richard, you were correct in stating that the tab looked like it was bent down. The service manual said not to try to bend the tab as it would break as it is hardened steel. It wasn't any good the way it was so I bent the tab back to a level position. It did not break. The exhaust valve is working as it should after the adjustment. Bob
I think there was s serial number break or something like that--one batch you could bend, the other you could not--I remember reading this in the manual. Anyway I know I have broken one, maybe 2. Too bad there isn't someone who repairs broken ACR components.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-26-2017, 12:21 AM
I would have just removed the 4 bolts on the cam cover and fixed it from there. Wouldn't have cost so much, or taken so much time to do from that hole. I mentioned that in post #6.
I agree you should adjust the valves. Especially since you have it out and all apart anyway.
Is the hole just stripped? I've put heli-coils in several and they held. Alvy is right, a cast iron pan fixes all issues.
Old 01-26-2017, 09:00 AM
sawdustdad's Avatar
I have to look at my 108 which has an ACR issue, too. It turns over and starts OK, but occasionally stops on the compression stroke and the starter belt squeals a little. But it's always started, so it more of an annoyance than a roadblock.
On the oil pan, I've Heli-coiled several. Get the kit, drill out and tap the holes, and screw in the inserts. Works fine. I figure if they lasted 40 years so far, the helicoil fix should work for another...And once you have the drill and tap set, the only cost is the inserts.
Old 01-26-2017, 08:11 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
JMech,
I have checked the valve lash adjustment and both valves were within specs. I do not remember the actual specs. now. I need to pull the oil pan as one thread was stripped and the other three were almost there. I would like to find a cast oil pan rather than try to fix this aluminum one. I appreciate your input and the other members input as well. What a great Forum and a great group of members. Have a great day.
Bob
