Old 01-20-2017, 10:45 AM
NCcubman NCcubman is offline
Default Spark plug question
Hey guys wanting to know what spark plug you like best for 12hp Kohler in a 102 upgraded probably a 1970 motor.
I picked up one from cub dealer but it's threads were much longer than current plug so I wasn't about to use it.. Manual says Champion RHIO but wanted to see if you guys have one you like best... Could be I bought it with the wrong spark plug in it to begin with but unsure.
I searched the archives but didn't see were anyone had stated a specific spark plug... Thanks
PS.. do you recommend using a lead substitute in gas for these older motors?
Old 01-20-2017, 10:52 AM
mortten mortten is offline
I use Autolote 216 plugs. Champion number should be H10C.
Doug
QA-36A
42" blade
Old 01-20-2017, 11:01 AM
I run Champion plugs.
No lead additive is necessary.
Read the manual. It tells you all this stuff.
Old 01-20-2017, 11:09 AM
Thanks guys just wanted some outside opinions... appreciate it
Old 01-20-2017, 11:11 AM
I use NGK sometimes and sometimes I use Champion.
Old 01-20-2017, 11:21 AM
johncub7172's Avatar
I use both the Champion and Autolite plugs. Going by the Operator's Manual, recommended plug is the Champion. I tend to reach for the Champion plug when at the tractor store more so, however.
Old 01-20-2017, 04:50 PM
Merk Merk is offline
I had too many problems with champions in the past. I will take Autolite sparkplugs any day.
Kohler manual says to run unleaded fuel in your engine.
Project Uncle Dick
Cub Cadet 70
Old 01-20-2017, 09:22 PM
I'm with Merk. No champion plugs in any of my engines. Autolites in my Cubs and they work great.
Old 01-20-2017, 09:39 PM
I can honestly say I never had an issue with the Champion plug regardless of recommended opinions of other enthusiasts.
