Old 12-31-2016, 11:10 AM
Originally Posted by jaynjeep View Post
Around here in South GA we get away running straight water.... but it never freezes here more than a few days a year.. never long enough to freeze a tire.
It's not always about the freeze. Water with air encourages rust if your running tubeless.
I use an inner tube on any tire that is filled with fluid.
Ditto
You guys do understand that beet juice and CaCl2 are not used for the non-freeze factor, right? No, they won't freeze, but they weigh more than water. Water and washer fluid is around 7lbs per gallon, beet juice/rim guard is about 9lbs and CaCl2 is almost 12lbs/gal. So, with a 6 gallon average per tire, water/washer fluid will give you 42lbs, whereas CaCl2 will give you 72lbs. Believe me, it makes a difference.
Old 12-31-2016, 11:14 AM
I have loaded lugs with 110LB wheel weights on my BX, they don't hurt the lawn at all and stay on year round.
Old 12-31-2016, 11:57 AM
OldSkull's Avatar
OldSkull OldSkull is offline
How about filling them with whisky Sam? This stuff doesn't freeze and you can have a drink if it became too cold outside.
Never mind, must be a Christmas brain fart!
Gilles.
1963 100 (red)/in storage
Old 12-31-2016, 12:13 PM
Use talcum powder Sam, then when you get IBS in the summer, you can take off the cap and let a little loose on your touche....
Old 12-31-2016, 02:18 PM
Ditto
Jon
At 12 lbs. per gal your close to the supersaturation point. I doubt that many places sell CaCl2 at that level of saturation. I'd bet more like 10-11 lbs. but it's still heavier than other options.
http://www.osi-univers.org/IMG/pdf/C...Handbook-2.pdf
Old 12-31-2016, 02:33 PM
I just jump in the pool when I get that hot and sticky.
Old 12-31-2016, 03:38 PM
Jon
Oh, I'm sure that is correct. I pulled a quick number off Google. I couldn't remember the exact number. 11 is what I thought it was before the search, but I saw like 11.8. That number musta been high.
Old 12-31-2016, 04:31 PM
EricWww EricWww is offline
Fascinating discussion. According to http://www.rimguard.biz/frequently-asked-questions/ Rim Guard is 10.7-11 lbs per gallon.
I think I will stick with the Rim Guard opposed to the other methods. There is one area on my yard I get some tire spinnage so I'm sure this will help with mowing too! I'm not super worried about the cost for a relatively small quantity - I'm remodeling my basement and the floor adhesive remover I'm using is almost $30 a gallon. I'll likely have the second dealer put it in- not sure if they would just sell the fluid for me to put in myself and everyone's closed til Tuesday. I have a bead breaker and plan on changing the valve stems to metal anyway.
My last 2 questions on this topic:
1) Just double checking but on a RWD tractor it would make no sense in putting in weight for the front tires right?
2) The turf tires are probably the original Goodyears that came on the tractor from the late 70s. They hold air and don't show signs of dry rotting. Any consideration for putting in Rim Guard into such an old tire?
Happy New Year everyone!
Old 12-31-2016, 05:19 PM
Like stated, Merk and I prefer not to put fluid in tubless. Small leaks, bead leaks... it prevents that. That said, tires that hold air will hold fluid. Tubeless with fluid is perfectly fine. If your tires leak air, they'll leak fluid.
No reason to add fluid to the steer tires.
Old 12-31-2016, 05:48 PM
Merk Merk is offline
I put tubes in all my tires. Too easy to hit a chuck hole and pop the bead. Tube tires won't pop the bead.
We had this discussion in the past......
Project Uncle Dick
Cub Cadet 70
