Old 09-13-2016, 10:31 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Very Nice Stanton!!
You have been hard at work!!
Jay
Proud owner of the following:
Old 09-13-2016, 11:03 PM
Motoing right along.
Grill shell turned out good, can't tell it was ever cracked...
Old 09-13-2016, 11:13 PM
jaynjeep's Avatar
Stanton,
Just curious.... I may have missed it earlier in the post but how are you getting the metal so clean? Are you using chemical stripper and then sanding?
It all looks great!
Jay
Old 09-14-2016, 02:21 AM
TheSaturnV's Avatar
Newcomer to this thread.
Outstanding work Stanton!
Old 09-14-2016, 07:43 AM
SGragg SGragg is offline
Inactive Member
Thanks for the comments.
Finished the lawn mowing ahead of the storms last evening and had time to disassemble the steering column. What a dirty mess. No wonder it didn't steer very well. Will be up-grading to the thrust bearing version like my other 782.
Was also going to open up the hydro unit for exterior cleanup and painting. Any precautions or no-no's to consider before separating the two? Do I just remove the bolts and lift the pump unit straight up?
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 09-14-2016, 10:02 AM
Dirty Steve's Avatar
Great job on the welding and the clean up. Your steering will be awesome when done. Keep at it!
Old 09-14-2016, 10:23 AM
Very nice work!
Old 09-15-2016, 07:49 AM
Inactive Member
Finished cleaning up the steering column last evening. As you can see, the steering pin had worn flat on two sides. Chucked it up in the drill press and used the angle grinder to reshape.
Ready for primer and paint.
Stanton
Old 09-15-2016, 11:53 AM
Nice job, Stanton!
Old 09-16-2016, 12:16 AM
Yeah that's how it's done on the cam follower. Good as new.
