Old 08-31-2016, 08:13 PM
Bob95065 Bob95065 is offline
Originally Posted by jsoluna View Post
Let's just all breathe out a sigh for the "previous owners" out there. It's a wonder these tractors held up this long.
It's a testimony to how well made these machines are. I'm using one that I beat on as a high school student. I have a second that was thrashed by a DPO. It didn't take much to get them both running right.
Old 08-31-2016, 08:59 PM
budscub's Avatar
budscub budscub is offline
Default Half dead IH cubs
You can certainly say that again. These old birds even when half dead are still twice the machine a 2 yr old box store mowers are.
But now, the box store machines are just that mowers. And provided your lawn is as nice a a golf course, and you meticulously maintain and clean the deck every time you mow, you might get a few years from one. We all know there won't be any of these around in 60,50,40,30 years.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 08-31-2016, 09:06 PM
ccguy's Avatar
ccguy ccguy is offline
Admittedly you have a good size set of challenges in front of you...but isn't that part of what drives us in restoring the equipment and giving it new life? You'll work your magic and I can't wait for the final reveal.
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 08-31-2016, 09:22 PM
Congrats on the 1250! I know the feeling like other QL owners, they just shake, but at full throttle its acceptable. I did the cradle mod and new iso's on my 1200, and it is as good as I can expect it to be on the vibration. I also recently acquired a 1450 in similar condition as your 1250 and there is a lot of work ahead, but it wouldn't be any fun if it were easy, right? TB
Old 08-31-2016, 09:28 PM
twoton twoton is offline
jsoluna, Enjoying following along, just my 2 cents..
... tune the engine ...
I think that is the key right there to reducing vibration.
I don't know why anyone would ever want to put solid mounts in a Quiet Line.
Unless it was a gear drive.
I chose factory replacements.
I think that's your best bet right there.
-44a deck...
It's hard to tell from the picture, I was just wondering what the diameter on your center drive pulley is, kinda looks like 5" making it a 44, I'm probably wrong.
Originally Posted by budscub View Post
is to allow the engine to bounce around a little bit
Exactly. That's why it's good for a hydro, not so much for a gear drive.
I also watched the driveshaft at low idle and I can see it moving outside of the centerline quite a bit. That rag joint that is spanning the distance where there should really be two joints is deforming and causing the whole driveline to vibrate.
Probably worn out ball bushing and maybe drive shaft too. Ball bushing keeps the shaft running true, rag joint transmits power.
Keep us posted!
Old 09-01-2016, 05:45 PM
jsoluna's Avatar
jsoluna jsoluna is offline
I'm going to disassemble it this weekend. I looked at the Service Manual and it doesn't mention it having two rag joints, just one as the does parts exploded view. Ball bushing should be fixed to the engine side or hydro side of the driveshaft?
Old 09-01-2016, 05:51 PM
mortten mortten is offline
There's a bushing mounted in a plate that bolts to the engine and there's a bushing in the coupler at the hydro. Later models had 2 rag joints. Here's the front bushing and plate.
Doug
QA-36A
42" blade
Old 09-01-2016, 05:58 PM
Here's the rear bushing.
Doug
QA-36A
42" blade
Old 09-01-2016, 06:29 PM
Another shot...
Old 09-01-2016, 07:38 PM
This was my 1650 when I first got it. One rag joint and a 5/8" cold rolled steel ball bearing in the transmission input yoke as it was a pre 622952 serial number machine. I went back with two rag joints and kept the ball bearing in place. Obviously had to get longer bolts. And I did that without loosening or removing either the engine or the rear end.
