Old 08-02-2016, 06:28 PM
twoton twoton is offline
Got a new 1/2” x 80” belt;
https://www.amazon.com/dp/B0018U053I...I3VCBPYTBZ8LYX
I also ordered up a 1/2" x 78" belt for my model 44a deck;
https://www.amazon.com/dp/B0018TYBM0...=I10EPB1ZY41S0
and a couple of new Stens v-idler pulleys (part # 280-188) for my mule drive off of ebay;
http://www.ebay.com/itm/Sten-280-188...cAAOSwEK9T25MO
Old 08-02-2016, 06:30 PM
Greased up the spindles and sharpened the blades and back to knocking down the weeds. Wow, this thing really cuts nice, love those front deck wheels.
Old 08-02-2016, 10:43 PM
Lookin good David that 1200 uses the wider belt right? Just got a 1200 and the ol boy crawfished on a deck --so i already have a
44a off a 129-uses a thin belt but this 1200 needs the wider one right? Got the carb soakin maybe mow w/it soon.
Old 08-03-2016, 05:34 AM
Thanks Brian. If your 1200 has the right PTO and the right mule drive it should all take the type A, 1/2" belt. (Which I would call the "thin" belt) The wider type B, 5/8" belt would be for the 82 series tractors with the 4" diameter pulleys on the mule and the 44c deck.
Old 08-03-2016, 11:52 AM
Your deck is looking great!
Old 08-03-2016, 02:33 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
This is where I am confused.
I tore up 2 - 1/2" x 81" belts on my 1200. (here is one http://www.ebay.com/itm/CASE-IH-4734...oAAOSwKtVWzSh0) The other was from TSC.
The sides kept tearing and shredding. It looked like it was rubbing on the sides. It was also VERY hard to get it on, as though it was too short.
Then I looked up the belt size through cubcadet.com and it showed a 3/8" x 81" belt. P/N IH-473462-R4
I also used the belt reference in the tech section and it showed a 3/8 x 81" belt.
I ordered a 3V810 belt and put it on, and it fits great. Used it for 3 hours and had no issues with the belt. I simply had to tighten it up a little bit after an hour or so.
Oh, and great work, as usual, on the mower deck!
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 08-03-2016, 05:39 PM
Thanks Allen! You havin' any luck findin' a new tractor?
, me too Jason. I have 4 QuietLines, 2, 44 decks and 1 44a deck. All came with 1/2" belts and have always worked fine. Got turned onto the Aramid belts through this thread;
http://www.onlycubcadets.net/forum/s...1&postcount=25
...but Maxwelhse is running a wide frame, do they use a different belt?
http://www.onlycubcadets.net/forum/s...53&postcount=9
How are your mule drive pulleys? maybe the're tearing up the sides of your belts?
Old 08-04-2016, 12:43 AM
bocephus1991's Avatar
For what it's worth I have a 1/2"x79" On my 1200 with a 44A deck. Haven't had any problems. I got it from tsc. Works for me!
Brian
Old 08-04-2016, 12:03 PM
Anytime! I sure have! It will be coming home soon. Stay tuned!
Old 08-05-2016, 08:51 PM
vr4Legacy's Avatar
Here is the manual I was using
http://www.cubcadet.info/Manuels/Bel..._1947-2004.pdf
And here is a screenshot of what I am referencing. (pgs B4 and E14)
I have a 38" deck, I think it's a 38A, but it's the same P/N regardless. I also looked at the 44A deck and it also says a 3/8 belt
-Jason
Tags
clutch, cub cadet 1200 quietline, rag joint
