Old 06-21-2016, 11:52 PM
longislandcubs longislandcubs is offline
My opinion is with those options, to buy one and restore it would cost you more. I would buy it. Good luck.
Old 06-22-2016, 12:41 AM
Terry C's Avatar
Terry C Terry C is offline
Providing they run the same I'd get the one with the plow and blade
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-22-2016, 07:36 AM
ironman's Avatar
ironman ironman is offline
Originally Posted by cadzag72 View Post
I don't think that's a cut-out on the back, that's the seat rest/tool box. It's just slid back as far as it can go. Aside from the decal mixup, looks like a nicely cared for machine.
Yes, I see now what you are saying. Kinda an optical illusion picture. Good catch!
Old 06-22-2016, 07:54 AM
ironman's Avatar
Looks like the second one has creeper too. I might be leaning towards it because if you don't need the plow you could recoup some of your money. But then again if you want to make it look like the first one your gonna put it all back. Coin flip?
Old 06-22-2016, 12:54 PM
On the surface it looks like the major differences between the two packages are a creeper gear and a turning plow.
If the first one was truly restored, with having the engine rebuilt and done correctly, it may be the better deal between the two.
Creeper gears have a terrific cool factor and they aren't cheap, but unless you plan to till garden or throw snow, you will probably never need it and turning plows can be had for $125.00 all day long.
If you're wanting something that is ready to go that you don't have to do any major work to the engine in the tractor is what really matters. If you're not an engine builder yourself, you could easily drop another $700.00 in an engine rebuild. Pretty much anything else with a tractor can be repaired in a day or two and for a considerable amount less than an engine rebuild.
Personally, if I were going to spend that kind of money on an old garden tractor, I would choose the one that is going to give me the the longest trouble free service.
OR, you could just get both.
Old 06-22-2016, 02:29 PM
TheSaturnV's Avatar
Don't get too hung up on spending $800+ on an "old" tractor. These things were made to last several lifetimes. Take your $800 to the Lowe's Depot and see what you can buy with it. Probably a fancy push mower. Either one of those machines looks to be worth the money. As Yosemite mentioned, it's all about the powerplants at this point. Find out if the "restored" one has had anything done to the motor, and ask about the other one as well. It could have been rebuilt in the last few years, and if done right will be a huge bonus for you.
Old 06-23-2016, 09:24 AM
ambrola's Avatar
ambrola ambrola is offline
Here is the add.
Owned this model 122 Cub Cadet since 1987 and have now upgraded to a newer tractor. Tractor starts right up and runs fine.
Features;
1. 48 inch mid-mount mower deck
2. IH front blade
3. Creeper gear
4.Implement lift
5. Brinly single plow
6. 3 speed manual transmission.
7. Original headlights
I am trying to reach him to see if any work has been done on the engine. Also, I would like to have it at 700.00. I think he will do the 7, but like you guys said, the engine is very important. I can't do a re-build and would have to send it out. What would a complete engine cost?
Old 06-23-2016, 06:07 PM
ambrola's Avatar
I talked to the guy with the 122 and attachments. The engine was completely re-built in the late 90's. He has all the receipts. I can get it for 700.00? I think I should pull the trigger on this one. He did tell me he took the front PTO off because the springs were gone and it was rattling?
Old 06-25-2016, 01:37 PM
ambrola's Avatar
OK Guys,
I bought the 122 with the attachments for 700.00. Someone tell me about the front PTO that runs the mower deck. It is off, but I have all the parts?
Also, is this the original seat?
Old 06-25-2016, 01:48 PM
No that's not the original seat , the original seat was white with a fiberglass pan and there very hard to find in good condition.
