Old 06-21-2016, 09:32 AM
WishIhada168 WishIhada168 is offline
Default Gear Drive Driveshafts?
Does anyone have the hole spacing for a shaft with a creeper? Or does anyone know where I can get a shaft made with a creeper hole but without the spring hole? I'm going to use a set of clamps instead of the spiral roll pin.
Old 06-21-2016, 09:59 AM
Contact member JeffinPA
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Old 06-21-2016, 10:29 AM
Some of the narrow frame and wide frame tractors had a groove around the standard length driveshaft to indicate where it should be cut for a Creeper.
Old 06-21-2016, 01:00 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
+1 for Jeff in PA
Easy to work with and quality work!
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 06-21-2016, 09:37 PM
Let me know what model you have and which hole you want skipped. ( a creeper driveshaft will only use holes 1-4 )
Jeff
Old 06-21-2016, 11:28 PM
I'm thinking hole #3
