Old 05-18-2016, 09:58 AM
Dodge71 Dodge71 is offline
Default Mule drives
I have a 126 cub I think it was built June of 67 if I ran the numbers right. I've been looking at some of the mule drives on this site. To see about (facing front of tractor)the left side pully having a spring on it to hold tension. Mine does not have the spring just a adjustment bolt like the right side. Is this normal or should it have the spring. Its working just fine the way it is . if its not broke don't fix it. Just asking was all
Old 05-18-2016, 10:24 AM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
The bolts on both pulleys is correct..... the build date is wrong tho... the 126 is 69-71 only according to tractordata.com
1969: 307000
1970: 322858
1971: 373301
Final: 400000
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 05-18-2016, 10:39 AM
1969: 307000
1970: 322858
1971: 373301
Final: 400000
OK I was only going by serial number chart I seen someplace maybe I read it wrong and its 69
Old 05-18-2016, 10:40 AM
Should there be a spring also
Old 05-18-2016, 11:12 AM
Lanceskene's Avatar
There isnt any springs on mine
Lance / Alberta Can
CCC 12.5 w/deck
Old 05-18-2016, 11:55 AM
OK so mine is good the way it is then I'm hoping its a 126 that's what the badges say are they the rare ones or the 123
Old 05-18-2016, 12:26 PM
Lanceskene's Avatar
126 is third lowest production model with 5,247 being made. Whats the serial # on your tractor?
http://www.onlycubcadets.net/forum/s...ht=Rare+cadets
Lance / Alberta Can
CCC 12.5 w/deck
Old 05-18-2016, 01:52 PM
The 38" and 42" mowers I've had on the 104/124, 106/126 series of tractors had a mule drive like this as far as belt tensioning.
Old 05-18-2016, 02:27 PM
I've seen mule drives made with adjustment bolts on both sides. I thought they were pin on decks not quick attach. Too many variations to remember.
Old 05-18-2016, 03:45 PM
Bob95065 Bob95065 is offline
Maybe it's a tiller mule drive?
