Old 08-11-2010, 09:52 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Ditto Matt's comments. This past weekend I got a 5 gallon pail of Hy-Tran Ultra from a Case IH dealer for $69 (part no. 372705R7). But if you have only one Cub Cadet then gallon jugs or quarts can be had from your local CC dealer, though the price per gallon is nearly double the 5 gallon pail price. Same stuff, just different label and price.
Neither Case IH or MTD make their own Hy-Tran fluid, but it has always been made by Viscosity Oil Company.
http://hytranman.com/since1963.php
Old 08-12-2010, 08:07 PM
hillbilly hillbilly is offline
Default Dextron, mercon
Since I can remember every trans my dad or I opened up hydro or stick good old automotive trans fluid is the onlything that went back in. I never seen it be any problem. As far as "moisture absorbant" anything that stits outside and sweets or has a leak in through the breather or shifter is going to build up water, and eventualy be a problem.
Old 08-12-2010, 08:44 PM
I've drained ATF out of a couple of mine because they were noisy and doing weird stuff. Hytran will absorb that water and it'll glob up and stick to the case or stay in the filter instead of going through the trans. ATF will not do that...
Old 08-12-2010, 09:42 PM
Merk Merk is offline
by Matt G.
Here is a few good examples:
