Old 02-18-2016, 03:05 PM
jim nicholson jim nicholson is offline
Default How to repair 108 plastic cowl
The plastic cowl is worn where the rear of the hood sits on it. a couple areas are worn thru. it doesn't look like fiberglass. Has anyone repaired these and what kind of epoxy or filler do you use? I have done fiberglass repairs before but not sure if it will adhere to this.
Jim
Old 02-18-2016, 03:31 PM
You could try this. I works well on Cyclops plastic on the ones I've tried so far. You can even form it into any shape you want. It's almost the right color too.
http://www.plast-aid.com/applications.html
Old 02-18-2016, 03:34 PM
It's fiberglass, you should be able to by resin to repair it at any paint supply store and most parts stores.
Old 02-18-2016, 05:46 PM
After I cleaner it up some I noticed some fibers sticking out and I wondered if it was fiberglass. That will be an easy fix then.
Thanks to all, Jim
Old 02-18-2016, 05:53 PM
I checked that website, That looks like fantastic stuff. I'm sure I'll find a use for it. The plastic knob on the mower lift stop is broken. I could make a mold and make a new knob
