Old 02-16-2016, 08:26 AM
kuleinc's Avatar
kuleinc kuleinc is offline
Personal experience working at a car shop... The rubber valve stems dry crack and leak be fore the tires wear out on low mileage vehicles...
Check out our videos and our instagram!
1967 Cub Cadet 123 and 122 | 1987 Vanagon Westy with 1.8T engine | 1986 John Deere 330 | 2007 Yamaha Grizzly 450 | 2007 Yamaha Wolverine 450 | 1996 Yamaha Blaster | 1988 Kawasaki JS440 | 1991 Yamaha Super Jet | 2006 Kawasaki STX-15F
Old 02-16-2016, 11:16 AM
Originally Posted by kuleinc View Post
Just finished mounting the rear tires today, not rounded or bulgy at all. I went with the 10.5 wide tire on the 8 inch wide rim. Carlisle tru powers...
If we don't get to see pictures, it didn't happen.
Old 02-16-2016, 06:07 PM
kuleinc's Avatar
I know, I'm really bad about that. I did the front tires today, wish I went a little wider than 6.5. Waiting on wheel bearings to come in, then pics!
Old 02-19-2016, 10:38 AM
kuleinc's Avatar
I don't currently have a belt on my front pto, should I leave it engaged all the time? It rattles when engaged, does this mean it needs rebuild or just a symptom of no belt? Should I dis engage it when no belt is on it?
Old 02-19-2016, 10:46 AM
Terry C's Avatar
Terry C Terry C is offline
I engage mine when I think of doing so. The bearing doesn't have to spin when engaged
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-19-2016, 11:24 AM
I try to leave mine engaged when there is no belt, that way the bearing doesn't have to work.
I also leave them engaged if they are going to set very long before being used again.
It may be rattling because there are no anti-rattle clips in it.
Old 02-19-2016, 02:28 PM
kuleinc's Avatar
Thank you for confirming, engaged is lever forward not pressing, just like a car clutch right?
Old 02-19-2016, 02:35 PM
Terry C's Avatar
Yes it is
Terry
3225
Old 02-19-2016, 03:34 PM
kuleinc's Avatar
My front wheel bearings came in today, might get some before and after pics this weekend weather permitting!
Old 02-21-2016, 09:54 PM
kuleinc's Avatar
Got the wheels installed, and replace the left front spindle. It was very loose. Steering is much tighter now. The tractor turns WAY shaper one way and barely at all the other way. I guess will be learning how to tighten up the steering box and adjust the center position on it next weekend. Sorry it got dark before I was done so no pics until next weekend...
