Old 01-24-2016, 08:02 PM
Default Thoughts after today's snow removal
First, the QA42 on my 125 just amazed me once again. Clearing my neighbor's driveway I had drifts up to hood height. Somehow the QA 42 managed to throw snow. My only problem was the cotter pin for the chute control broke ( I've had the QA42 for 12 years ). Neighbor Vic had the correct size hair pin and I was back in business.
Second, I really like my IH Windbreaker but I think at just under 6' tall and 220 lbs, I'm about maximum size for anyone to comfortably use one. As snow collected on the roof, it touched my head and also my left knee was against the door so I could control the speed / direction with the hydro lever.
Snow coming into the cab wasn't too bad. I have a hydraulic lift on the 125 and the IH Windbreaker wasn't sculpted to fit around it.
All in all it was a good day.
Old 01-24-2016, 08:03 PM
Looks good Jeff.
Old 01-24-2016, 08:11 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Glad it worked well Jeff!
My thoughts are keep a spare belt!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-24-2016, 08:21 PM
I have spare belts for the starter generator, the QA42 snow thrower and both spare belts for the 42" cast iron end mower deck. I "think" I have the correct belt for the hydraulic lift but I'm going to measure it to make sure.
I'm going to add a couple cotter pins to the under seat storage too.
Old 01-24-2016, 08:32 PM
Jeff, glad you had a great day in the seat and your cub performed well. Looks like the chute on your snow thrower is stubby. I wonder if you extended it or had a fuller chute, then maybe you would not have the snow build up on top of your cab as much.
Old 01-24-2016, 08:41 PM
It was still windy this morning so I was getting "swirl".
I stayed warm and dry so it was only a minor inconvenience.
Old 01-24-2016, 08:42 PM
Jeff,
Once you go cab,you never go back.
To the motor cycle helmet.
Up to 534 and counting...
Old 01-24-2016, 08:46 PM
My thoughts on snow is that snow sucks, cold weather sucks. I'd rather be cutting grass and sitting by the pool in 90 degree weather. Yeah I know It's good to want. Did I ever mention that I hate snow?
Old 01-24-2016, 08:54 PM
come on Sam, you know the kid in you was having fun.
Old 01-24-2016, 09:11 PM
Jeff,
If I need to use the blade on the other 125 it'll be motorcycle helmet time
