Old 12-18-2015, 02:39 PM
SS5150's Avatar
SS5150 SS5150 is offline
Default 782 3pt hitch
Question, I have 2 IH 782s, under 720,000 serial#. My question is, can the #389 3pt hitch fit the lower serial # tractors, or will it need to be adapted, or is it a no go all together? I thought the newer mtd 782s had it as an option & I'm trying to figure out if it will work on the older tractors.
I have the IH rear lift on 1 of them already, just wondering if the cat. 0 is doable.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 12-18-2015, 03:56 PM
Yes. Should bolt right on. Could possibly have to drill a hole in the frame, as I'm not sure that they are already drilled/punched, but it will play.
