Old 09-05-2015, 12:17 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Default First of... More??
I mentioned about a year ago maybe building a few of these that were cub sized. About 2 months ago a guy, very interested in my larger version, wanted one for his JD 425.
So here we are, building my first authentic version of the R-Bucket. I actually have two models drawn up, the one currently in production is a RB-46. It is Super Garden Tractor sized at 46" wide.
I have a request for a garden tractor sized model that will be around 38" wide. Hence the model number would be RB-38.
I am building templates to speed up the process of production, so in the event somebody requests one, it can be done in a reasonable time frame.
ANYWAY, Keith (Nightow1) and I picked up the sheet metal last night and cut out the sides and main bucket. Today we went to a near by welding shop to get material for Keiths 3pt and the R-Bucket. While we were there we had the bucket heal bent. We then tack welded the sides on and started prepping the center pieces.
Keiths daughter has picked up the hydraulic cylinder, hoses, and fittings at surplus center, that stuff should be here on Sunday!
Here is where we are currently! ... Stay Tuned!
Old 09-05-2015, 07:33 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Very cool.
I am broke, but I make it work!
Old 09-06-2015, 11:37 AM
Looking good so far, can't wait to see it finished.
Old 09-06-2015, 07:12 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
looks great so far
Old 09-06-2015, 11:33 PM
Rescue11's Avatar
Thanks guys, i did some welding on the bucket yesterday. Had a design change that will require different metal than i have in the pile. Have to wait till tuesday.
Old 09-06-2015, 11:42 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Looking great.. please keep us posted!
Jay
Proud owner of the following:
Old 09-11-2015, 11:51 PM
Rescue11's Avatar
This afternoon turned into a mildly progressive one. Got the frame started on and slots cut in the bucket. A good majority of the time was spent building a jig to uniformly cut out the slots in the bucket for the frame and cylinder. Once finished the jig made quick work of cutting the openings.
Old 09-14-2015, 01:59 PM
Rescue11's Avatar
Worked on the R Bucket a bit last night. Started to built the frame rails for the bucket. Got all the angles figured out, built a jig to cut them, and recorded all the measurements.
This is one of the two rails required for attaching the bucket to the frame. Hopefully there will be time tonight to make the othr rail, then glue them to the bucket and give it a rang of motion test.
Started out with box tubing and ended up with this...
Old 10-11-2015, 11:50 PM
Rescue11's Avatar
Welded, cut, drilled, ground... getting closer!
Old 10-12-2015, 05:23 AM
twoton twoton is offline
Nice work there Rescue11.
