Old 08-17-2015, 07:35 AM
Unseenthings Unseenthings is offline
So here was the problem head with the stuck valve
Old 08-17-2015, 07:46 AM
We managed to get the head replaced with the motor in the tractor. It runs pretty good, but could be better I'm sure. Having trouble figuring where exactly the throttle and governor springs go, if anyone has a top down picture I'd like to see if they are connected properly.
As it is, it is a terrible mower for the yard, spins out on every little hill it seems, can't hardly climb anything. Do I need wheel weights? Never used those before, are they generic or custom?
I don't think the rear brake controls are working, can't lock up a wheel in spin.
Any way to get more speed out of reverse?
Thnk-you
Old 08-17-2015, 09:38 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Brakes are easy to adjust, get some wheel weights for petes sake. Atleast 75 lb ea... will be a different machine. Dont have to be special. Cheap plastic covered cement weights for like 100 bucks will fit... ANY 12" weight will work... deere simpl bohlens etc...
Old 08-17-2015, 10:02 AM
timbo2's Avatar
timbo2 timbo2 is offline
From my 2284-
- Tim
Old 08-17-2015, 10:04 AM
Thanks for the picture Tim
First glance those weights aren't as easy to find as one would think.
Also forgot to mention, won't start with key, solenoid is good. Would it be that small black relay down by starter with like four wires in it?
Old 08-17-2015, 08:56 PM
bugeye bugeye is offline
There are multiple safety interlocks. Brake must be depressed, transmission in neutral, PTO off and seat occupied. If all interlock switches are made, then the relay energizes providing power to the starter solenoid. My 1864 does not have the relay. I have had to replace the key and brake switch as they both became unreliable. I also think my PTO has occasional random times of no continuity. So, the PTO is next to be replaced. After 20+ years with year round use, new switches are due.
Old 08-17-2015, 10:40 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Loading the tires with water or ballast fluid will make as much or more difference than wheel weights.. It is also a lot cheaper than weights. it will be a different machine with weights or ballast fluid or both.
Jay
Proud owner of the following:
Old 08-24-2015, 06:49 PM
Can I run a wire directly from key switch to relay?
Old 10-22-2015, 12:23 PM
Toro is fixed. Will be taking offers on the 2084 in the $800 range.
Old 10-22-2015, 12:25 PM
jimbob200521's Avatar
Did you get it fixed? Does it have the 3pt? What comes with it? Details, man! I may be interested
-Ryan
