Old 07-30-2015, 11:52 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
I'm almost certain I'm gonna use CaseIH paint. I've not heard any negative comments about it from anyone here who's used it. May stop by the PPG dealer and price a lower end auto single stage paint too.
PPG's Omni line MAE is pretty strong stuff. Painted my wheels with it and they still look like new after 4 years of mowing, dirtwork and snow removal. Easy to shoot too.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 07-31-2015, 12:26 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I have used the Case IH argent silver paint on tractor rims with good luck before.. I have also used the Omni line single stage with good results.. wouldn't shy away from either one
Jay
Proud owner of the following:
Old 07-31-2015, 01:06 AM
Adam, the paint for my original project I thought was reasonable, from my IH dealer. (at least I think so) I got two quarts paint, gallon of reducer and hardener for bout $100.
Seems like decent paint to me..
Old 10-02-2015, 06:03 AM
IHinIN IHinIN is offline
An update on progress.
The hood is ready for body filler finally. I welded shut several extra holes, made and welded in a new brace, and built up where the hood was nearly worn thru where it rests on the top of the grill casting.
The spindles got braces welded into the corners to prevent them from bending.
Old 10-02-2015, 12:56 PM
Jumper Jumper is offline
Adam, Looking really good so far , while your looking for cracks, check the front axle mount (if you haven't already) where it's welded to the frame.a.jpg Three of the five narrow frame tractors I've worked on has had this problem.
Old 10-02-2015, 01:07 PM
Thanks!
Mine was cracked worse than that when I got it. That's already been repaired.
Old 10-02-2015, 07:11 PM
Omalon Omalon is offline
Great job and keep the pictures coming.
Old 10-03-2015, 08:03 PM
Started sand blasting some parts today. All of the engine tins and brackets and clutch basket pulley are ready for paint.
Oh, and I'll just leave this here.
Old 10-03-2015, 08:20 PM
Ahhhh, now I see. Spindles with gussets......it all makes sense now. Sweet can't wait to see the "cough" come together as well.
Old 10-03-2015, 08:52 PM
Sugarmaker's Avatar
Good progress on the restoration work.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
