Old 07-24-2015, 06:07 PM
Fitz14's Avatar
Fitz14 Fitz14 is offline
Default 1863 power steering update
I finally got my power steering fixed. The steering pump (box) was bad. I got in touch with the po and took it to his shop. He put another pump on it and the upper steering column. It was hanging up a little at the joint.
Anyway I now have one finger power steering.
As for as the plumbing, it's exactly the same as I had it in the pictures on my previous post. It can only work one way, so I know it's correct.
Thanks to everybody for the suggestions. Especially Sam for all the time he spent trying to get this thing going. It's all appreciated.
Old 07-24-2015, 07:11 PM
Congratulations!
I'd bet you are loving that 1863 now!
Old 07-24-2015, 07:55 PM
Thank you for posting the results, it helps a lot of ppl even those who do a google search.
Old 07-24-2015, 08:01 PM
Jim
Glad to hear that you got it working. When you get time please post pics of the way it's plumbed now. I hope to learn from this one so that if it comes up in the future I'll be better informed. Maybe the service manual is wrong about what are the pressure and return lines. I just want to understand more about what the issue was. Good to see that the OP manned up and took care of the problem. Too many won't stand behind what they sell.
Old 07-24-2015, 10:15 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Good deal, glad you figured it out! ...so glad you didnt sell it???
Old 07-24-2015, 10:21 PM
Fitz14's Avatar
Here's the old and new pics. I already had the pan back on, but you can see they are going in the same.
Old 07-25-2015, 05:04 AM
Handpumps don't fail..... They will leak, and I've had to replace a few but it's extremely rare.... and it was on a larger machine with 10K plus hours on it. My bet is the OP "rebuilt" it and put the valve rotor (or possibly another part) in wrong. They will only work installed one way. There are several different fails if it is installed wrong. It may steer hard. It may "motor" on it's own to max one direction, or the other. It may not work at all (can't even budge the wheel). Ask me how I know. My bet is the one you had could have been repaired/ fixed ... but doesn't matter now.
Glad you got it fixed!
Old 07-25-2015, 08:52 AM
Agree with J mech,
What I'd like to know is exactly what did he do to take care of the problem?
I resealed a "pump" that had the 2 springs crushed, but the effort was normal, it just was leaking slightly.
After resealing it and putting in 6 new springs, it worked fine except with slightly more effort.
Took it back apart and nothing wrong, so wondered if using lighter springs or omitting 1 large and 1 small would allow less effort??
Experience Johnathon?
Old 07-25-2015, 11:00 AM
Fitz14's Avatar
I ask him about rebuilding it and he said he doesn't rebuild them. He just put another one on it off the shelf. Maybe somebody rebuilt it before he got it. We'll never know.
Old 07-25-2015, 01:27 PM
Agree with J mech,
I've never tried eliminating springs. In theory, I can't see that it would make any difference because their job is to center the valve rotor after you stop steering. Not sure why it steered slightly harder after a rebuild, I just don't know that that ever happened to me. Not that I noticed, or anyone mentioned anyway.
