I have the PTO clutch off K301 trying to remove starter/gen pulley off so i can replace keyway in end of crank. Does it just pull off or am i missing something?
1433464415535.jpg Any help would be greatly appreciated!!!
John |
Lock ring on the back side needs to be loosened opposite the way the engine turns, about a quarter turn. There is a set screw in it.
I got the set screw out but did not try turning lock ring! Figured i was missing something!!
Thanks a million Dan. How about the throw out bearing? Any tricks i need to know about that before I tackle that tomorrow?
John |
I sometimes wind up putting a 3 jaw puller on to get them off .
If you have a flywheel puller you can try something like this. Not as good as a 3 jaw puller just takes a few tries.
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
