Old 05-24-2015, 07:27 PM
twoton twoton is offline
So… I got my points saver installed, and my new coil and spark plug wire.
Thanks Dave!
http://www.kirkengines.com/#Products
Update:10-05-2015, 07:17 AM;
http://www.onlycubcadets.net/forum/s...703#post347703
Old 05-24-2015, 07:29 PM
And my new air filter;
http://www.amazon.com/dp/B00062YN64/...I2I1TGULO39UE0
and installed a new spark plug, (gap .035 inches);
http://www.amazon.com/dp/B000F0K0FK/...=IRTZPYUOSFQHJ
and points;
http://www.amazon.com/dp/B0015MLULK/...I33EIKVQFGFNEL
Set the timing like this ( turned out to be .018 gap at the points);
http://www.mgonitzke.net/cubcadet/to...tic_timing.pdf
And installed a new points cover gasket and grommet that I picked up from our sponsor here;
https://www.facebook.com/CubCadetand...9696141763776/
Old 05-24-2015, 07:31 PM
And,… following the thread in the tech section on how to destroy a perfectly good muffler,…
I cleaned out my muffler.
Old 05-24-2015, 10:49 PM
Why would you do that? ..........
Old 05-25-2015, 06:57 AM
Just bored I guess.
Old 05-25-2015, 03:22 PM
bocephus1991's Avatar
You tore that apart intentionally??????? Never been that bored
Brian
Old 05-25-2015, 03:53 PM
Me neither......
Old 05-25-2015, 06:02 PM
From Dave Kirk's Killer Kohler Part 2
http://www.kirkengines.com/downloads...hlerPartII.pdf
"The standard muffler used is a three-chambered affair, housed in a 12 inch long by 5 inch
diameter can. While effective at reducing noise, it is somewhat restrictive to gas flow as
compared to a straight through glass pack. Searching several catalogs yielded nothing in
a high performance muffler in this size and configuration. A serviceable, used, standard
muffler was thus obtained and the end cap removed by grinding away the crimp. The
internal baffles and central tube were then removed by chisel and hammer, carefully
breaking through the spot welds. After removal, an empty can remained. A ¼ inch thick
sheet of muffler fiberglass wool was carefully measured and cut to line the inside of the
can diameter. A matching sheet of perforated steel was cut and placed inside of the
fiberglass wool. The perforated sheet was tack welded on the seam such that it forms a
rigid cylinder to tightly hold the fiberglass against the outer can walls. The end cap was
welded back on and the muffler painted with high temperature “barbeque black” paint. It
looked totally stock from outward appearances.
I reassembled it to the engine, eagerly anticipating the sound to be pleasingly noisier. To
my amazement, the muffler was actually quieter than stock! But it did have a nice, deep,
healthy sound, especially when the engine was carrying a heavy load. I had to slightly
richen the high-speed needle setting on the carburetor – a positive sign indicating that
airflow had been increased by this modification. Instead of the exhaust flow having a
tortuous and restrictive path to the outlet, it now exits into a large volume plenum with
pressure waves muted by the absorption properties of the wool. The engine now felt
stronger than ever with a baritone authority to its voice."
Thanks to Dave Kirk.
Old 05-25-2015, 06:06 PM
Got all my stuff together for my spindle upgrade;
Old 05-25-2015, 06:09 PM
All ready to be welded.
http://www.onlycubcadets.net/forum/s...587#post344587
And painted. I used the ol' "glop it on till it starts to run, then you're dun" technique.
And got a couple of new rims. From here;
http://www.cedarrapidstire.com/produ...-75-0815293266
Thanks to these guys for the idea and parts links;
http://www.pf-engineering.com/spindle-upgrade
Tags
clutch, cub cadet 1200 quietline, rag joint
