Old 05-23-2015, 08:17 PM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default 1200 steering L & R
Question for you folks, Is the turning radius suppose to be the same L & R?
Not sure if I got something slightly off, I've got great turning radius on the left non discharge side, but right side is less.
with the Steering wheel centered and wheels straight the arm on the steering box is down in the 6 o'clock position
make sense?
Thanks
David
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 05-23-2015, 09:54 PM
Turn lock to lock and count turns. Turn steering wheel half of the amount and it should go straight. If not, adjust the length of the rod from the steering box to the one steering knuckle to compensate.
Old 05-23-2015, 09:56 PM
YES
Turn the steering wheel all the way CCW. Now turn the steering wheel the opposite direction counting the turns. Now turn CCW to the "half way point" and unhook your linkage(s). Put the front wheels straight ahead. Adjust your linkages to achieve this.
