Old 05-17-2015, 06:52 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Ha! No it's a cummins that happens to be wrapped in a dodge shell.
-Rick
IH 782
IH 126
CCC 1863
Old 05-17-2015, 07:02 PM
OH! Well it's definitely a keeper then! That cover is a PITA to get too. I feel your pain. BangKohlerStack.gif
Old 05-17-2015, 07:09 PM
Rmowl's Avatar
My wife supports me with my cub addiction but when I proposed the new mods for the dodge she suggested I move one and I had to agree with that. Kinda stinks but such is life, thanks for all the replies though.
-Rick
IH 782
IH 126
CCC 1863
Old 05-17-2015, 09:18 PM
Great thanks for quick replies. I'll take the head to machine shop when I get home. Lounging around hotel now down Spartanburg sc way. Hate to sell the thing but truck needs a new tappet cover and while I have whole front end tore apart gotta performance cam to slide in and some more air to shove down its throat, and the 102 is the least used tractor
You can resurface it yourself.
Here's how I do it. A piece of plywood to secure the 600 grit emery (sand ) paper, a piece of window glass, a stapler and some water.
Use a circular pattern and check often to make sure you are pressing evenly.
Old 05-17-2015, 09:19 PM
Don't forget proper torque specs and correct tightening pattern too.
File Type: jpg IH_Kohler_Serv_Man_1-05_head_torque.jpg (21.4 KB, 141 views)
Old 05-17-2015, 10:38 PM
Rmowl's Avatar
Jeff, thanks! That sounds like something I can do! Thanks a lot! I saw in another post some time ago your in Allentown area. I was just up that way a few wks ago en route to Milford pa area, I'd like to stop by your shop I know Lehigh valley pretty well. Im just a rambler from east tennesse that happens to live in western md now. Anyways thanks! Also I have gotten a lot of compliments on your sleeve hitch that's on the 102
-Rick
IH 782
IH 126
CCC 1863
Old 05-17-2015, 10:53 PM
It's not hard to do, just watch your patterns as you make your circular motions. Clean the paper as needed too.
Use "modern" glass that is flat ( I grew up in a house that was built in the 1840's and the glass was wavy )
Good to hear the sleeve hitch adapter gets good reviews
Old 05-17-2015, 11:02 PM
Merk Merk is offline
Originally Posted by cubby102 View Post
If you really want to put new bolts in it I don't see a issue with it. I have gotten them from the hardware store in the past. I'm sure someone that has done more engines then me will chime in. But I've used grade 5 bolts when I've had to replace broke. Or rusted bolts on the heads
You should always replace the bolts and studs when you remove the head. The fasteners have been through heat cycles and loose their tensile strength.
Grade 5 bolts????
I hope you are kidding. My first choice is Kohler bolts and them grade 8 bolts.
Project Uncle Dick
Cub Cadet 70
Old 05-17-2015, 11:30 PM
cubby102's Avatar
cubby102 cubby102 is offline
The grade 5s were put in almost 10 years ago and are still holding up great. Not saying it's right though maybe I just got lucky. If I ever have to pull it apart again I'll swap em out
Old 06-09-2015, 07:51 PM
Rmowl's Avatar
Jeff, I resurfaced the head using your technique when I got back home and got the new gasket on. Put about an hour on it and so far so good! I briefly had it on the chopping block and my wife of all people said it was a horrible idea to get rid of it. It doesn't get many hrs put on it but don't think I could replace it. Thanks for help!
-Rick
IH 782
IH 126
CCC 1863
