Old 04-01-2015, 07:08 AM
BigB87's Avatar
BigB87 BigB87 is offline
Default 108 with brake on PTO
I rebuilt the clutch in my 108 and it doesn't do as good now. It had 2 disks before i rebuilt it and only put one back in. Would this cause my problems? I know when its engaged it shouldn't slip much or at all. I can put a belt on it and hold it still with my hand (I know dangerous) but its driving me nuts. I have my tiller mounted to it and have to ride the clutch along with being in 1st in low range to till some soft stuff. But should I put 2 disks in or just leave the one?
Brandon
CC models: 86, 1650, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1978 1650 Hydrostat w/44" mower & 42" IH push blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 04-01-2015, 08:39 AM
I used two discs in mine. I had the opposite problem with mine, it was difficult to disengage. Sounds like you need to tighten the three adjusting screws tighter.
Old 04-01-2015, 08:45 AM
BigB87's Avatar
Well when i do that it stays engaged and can't disengage it at all
Brandon
Old 04-01-2015, 09:34 AM
Two friction disks? Or two springs?
Adding a second friction would do nothing for holding power. Not unless you added a steel disk that is connected to the PTO (like the rear steel) between them.
Did you install a new spring? You sure all parts are correct? Did you use the gauge to adjust it? Not pointing fingers, but I'd say you either installed incorrect parts, or didn't assemble it right.
Old 04-01-2015, 09:40 AM
BigB87's Avatar
Well ive readjusted it 3 or 4 times and it gets better then worse. Kinda new to rebuilding a mechanical clutch. Never had many problems
Brandon
Old 04-01-2015, 09:41 AM
Mine had two friction discs and two triangle springs, it's a late production 129. Seems like the manual says you can use two friction discs on HD applications, mine had two when I bought it, so I put two back in it.
Mine didn't stop the PTO well until I replaced the brake lining on the PTO arm, it also brought the adjustment on the actuating rod back into range.
Once you figger it out you will smack your head, I was trying to make it harder than it really was, works like a regular mechanical clutch, the center button is like a throwout bearing.
Old 04-01-2015, 09:45 AM
BigB87's Avatar
See my 108 was set up fir heavy duty and the motor i put in came out of 129 that was also heavy duty. So it has dual spriings and disks i just put 1 disk in
Brandon
Old 04-01-2015, 09:46 AM
The only thing adding two frictions would do is add surface area to the "teeth" on the friction disk that rides in the basket. (Less likely to wear the edge of the "teeth" off.) It does nothing for holding power. There is no reason that with one disk that you should not have been able to adjust the PTO.
Old 04-01-2015, 12:25 PM
BigB87's Avatar
Well im at a loss here. Luckly my garden is tilled now but had to use my reartine walk behind
Brandon
Old 04-01-2015, 01:45 PM
I used the gauge to set mine 3 times and it was too tight each time. I ended up assembling the clutch, tightening the 3 screws until I could no longer slip the clutch by hand, then went one round tighter on each screw. This was on advice of a good member here, and it worked like a charm first try. Tilled my whole garden a week ago today and it worked great.
