Old 03-24-2015, 09:32 PM
cub125 cub125 is offline
Default Is this too much clutch release lever wear?
I disassembled my clutch today to determine what wasn't broken, the pressure plates and throw out bearing look ok but the shaft is bad, and the spring is broken. The release lever has some wear around the center, there was not a teaser spring or spacer in between the bearing and the pressure plates, should there be?
Old 03-24-2015, 09:38 PM
Merk Merk is offline
What model Cub Cadet?
All of the manual trans IH Cub Cadets had a teaser spring.
Release lever needs replaced.
Project Uncle Dick
Cub Cadet 70
Old 03-24-2015, 09:52 PM
It is a Model 100
Old 03-25-2015, 12:19 AM
cubby102's Avatar
cubby102 cubby102 is offline
I would say yes that one has had a long life. . Yes there is supposed to be a teaser in between there. Are you sure that the bearing is good? That throwing lever is chewed up pretty good. One of the worse that I've seen at least from that angle.
Old 03-25-2015, 12:35 AM
Be sure to have your plates turned before you put it back together.
Old 03-25-2015, 10:03 AM
Thanks! I am having a machine shop turn the plates, the bearing spins freely, I am thinking the bearing has been replaced at some point because the shaft has a lot of wear but the bearing looks good, whoever replaced it might have left the teaser spring off.
Old 03-25-2015, 04:06 PM
ironman's Avatar
ironman ironman is offline
According to another site, you can use a spacer and a 5/8" lock washer instead of a teaser spring. I have done this and it works fine.
