Go Back   Only Cub Cadets > Resources > Cub Cadet Parts Sources
Old 03-03-2015, 01:16 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Glow Plugs
I did some searching for the various parts for my 782D and was on the hunt for the glow plugs. I came across this site, it's kind of a hard one to find information on. So here is the link for the plugs, I hope this helps anyone else.
http://www.ngk.com/product.aspx?zpid=16044
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 03-03-2015, 10:41 AM
sbauerz28's Avatar
Those are the standard plug I think everyone uses. If you want a better and hotter plug use a Y702R. They are more money, but with everything else you get what you pay for.
Old 03-31-2015, 09:06 AM
Earl, on the original design of the gp circuit in start and pre-heat mode, the power goes out on terminal #19 of the key switch, through the indicator and back to terminal #17 on the key switch and then to the gp's. (terminal #17 is a dummy terminal)
All that the dash indicator does is glows red hot from all the amps that the gp's pull. The original gp's don't get 12 volts because of this indicator and the voltage drop it causes. The new gp's need the full 12 volts and this indicator causes a voltage drop and robs power to them.
With the new gp's in the machine you will need to take the indicator out, move the orange wire off of #17 and move it to #19 and then use the orange wire that powered the gp's to energize the gp solenoid.
