Old 02-11-2015, 05:39 PM
Redneck #1 Redneck #1 is offline
Default Electric PTO Clutch
How warm/hot should the PTO clutch get? After running it for less than 5 minutes, the frame work behind the pulley was hot enough you did not want to leave your hand on it very long. Is this normal?
If not any ideas what to do?
I never had occasion to really check one after running it.
Thanks
Old 02-11-2015, 06:39 PM
kostendorf's Avatar
Make sure it is adjusted right. What tractor is it on?
Old 02-11-2015, 06:54 PM
It's on a 1861.
What adjustment would cause it to get hot?
Old 02-11-2015, 07:02 PM
Originally Posted by Redneck #1 View Post
It's on a 1861.
http://www.onlycubcadets.net/forum/showthread.php?t=30
Just a FYI the coils do get hot.
1st they are bolted to the front of the engine directly under the exhaust system.
2nd they are an electric coil.
Over 200 is pretty normal.
Old 02-11-2015, 07:03 PM
kostendorf's Avatar
If its not adjusted right it does not lock on and causes friction which causes heat. There should be instructions in the manual section on how to adjust the pto.
Old 02-11-2015, 07:23 PM
Thanks. I will check the gap and other specs.
