Old 02-02-2015, 08:28 AM
I think you all need to watch the video again. It appears to be missing one of the two bolts that hold the lift extension on( or whatever its called) you can see it pivoting on the one bolt but there should be 2 and you can clearly see its missing.
Old 02-02-2015, 08:35 AM
mmzullo mmzullo is offline
Use a clevis pin in the second hole. There is no down pressure. Looks like the rock shaft is not moving much. If you look it's pivoting in the middle.
Old 02-02-2015, 09:42 AM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
You nailed it Tim. Good eye. I did not see it until you stated it. I know my lift will not work without something in both holes.
Bob
Old 02-02-2015, 10:36 AM
Berwil's Avatar
Berwil Berwil is offline
Tim the upper bolt is to lock out the float, unnecessary for lifting. If you watch the video his deck arm is stuck almost all the way up, yet the blade is still on the ground. You can see small movement of the deck lift arm at the upper end of cylinder travel, but the outer lift arm bracket is not moving as much. There is a disconnect on the rock shaft somewhere, one of the pins is broke.
Bob, if yours will only go up and down with 2 pins, I suspect the rock shaft is half rusted and not moving freely. It should go up and down with just the bottom pin in place.
Here is a pic of my lift arm extension, only the bottom bolt is needed like in the op's machine. Pay no attention to the bar in the background.
Bill
Old 02-02-2015, 11:24 AM
OK that makes sense, I've never seen one that didn't have both pins.
Old 02-02-2015, 11:42 AM
More than likely the outer rockshaft pin is sheared. Yes, the second hole is for down pressure. It is not needed. The reason that it is rocking of the second pin is because the blade is already on the ground. It is also possible that the lift rod to the blade is too long. Fix the broken pin to know for sure. You can test with the bolt that you put in. As long as no other pins are sheared.....
Old 02-03-2015, 10:07 AM
Mr Bob's Avatar
Berwil,
My tractor will lift with just one pin in the bottom but there is a lot of play due to pin holes being worn after 40 some years. Also the floating piece that the pin goes through has a lot of wear at the angle part as it fits to the other bar. I get about 3 more inches of lift up front by using 2 bolts as this took all the play out of it. I then use a chain to front implements to keep from damaging the hyd. system. My rock shaft and pins are in reasonably good shape. Thanks for your input though and I believe that you are correct in your assessment of the op's lifting problem. Have a great day all.
Bob
Tags
149, hydraulic lift
