Old 01-13-2015, 10:53 AM
overtime hank's Avatar
overtime hank overtime hank is offline
Default Steering wheel stuck on 102
Ok guys I have been trying to get my steering wheel off my 102. PO welded the top of the shaft for some reason. The box itself seems tight but,theres always a but, I can see the gasket is broke and hanging out. I have been soaking it down with kroil and pb, Iam using the 5/8 bolt and knee trick,while beating it the steering wheel plastic is breaking off I'm down to the steel on the hub and spokes. Am I doing damage to the gears in the box??? This has me worried also now the shaft is moving front to back side to side about a 1/4 inch. Looks like these steering boxes aren't cheap. I hope I can salvage it. What do the cub guru's think
1978 / 1650 Dual stick, 50a Deck, 42 Blade
1966/ 102, 44 Deck, 42 Blade
1951/ IH Refrigerator, turned kegerator
3 more IH cubs in the works
Many MTD Lt's and 1 Huskee Gt
Old 01-13-2015, 11:11 AM
You can probably get as many answers to this question as there are people here.
If the plastic is already broken away, you can heat the the center of the wheel with a torch.
If you are hammering on the top of the shaft, be careful, I knocked the bottom out of the aluminum housing one time doing that.
This summer, my Brother told me that the bushing was worn out in the 105 and he couldn't get the wheel off. I suggested that he loosen the nut spray some penetrating oil on it and keep on mowing. About 3 or 4 mows later the wheel was loose and he replaced the bushing. I realize this isn't an option for everyone.
Old 01-13-2015, 11:18 AM
I also suggest taking the nut off and spraying it with pb the driving it around, its about the only way to guarantee no damage to the wheel or column.
Old 01-13-2015, 11:22 AM
I'm thinking about sawzalling off the steering wheel. Is that hub really hard metal??? Driving it around is not an option it's in many pieces and split in half.
Old 01-13-2015, 11:24 AM
Yes, I highly doubt you can cut the wheel off without damaging the column.
Old 01-13-2015, 11:40 AM
Was I supposed to have the two mounting bolts out on the gear box before beating the snot out of the 5/8 bolt???
Old 01-13-2015, 11:55 AM
I've done it with and without the bolts in, without the bolts seems to lesson the chance of damaging the column.
Old 01-13-2015, 12:46 PM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
Use an air hammer with slight up pressure on the hub. It is the closest thing to magic. Great on flywheels.
It this point being the plastic is broke,break off the rest around the center hub,then put the nut on and use a 2 or 3 jaw puller on it ,easy peasy poppsy offsy.
Up to 534 and counting...
Old 01-13-2015, 05:35 PM
Bob95065 Bob95065 is offline
On my 1450 I loosened the nut so 1/2 of the threads were over the top of the shaft. Next I threaded a bolt of the same diameter and pitch on the exposed nut so that it was contacting the shaft. I sat on the seat with my knees under the wheel putting pressure up. With the pressure on the wheel I hit the bolt with a hammer jarring the wheel loose.
I left out that I soaked the wheel/shaft interface for days with Kroil. It came off pretty easy. This tractor had sat outside for years too.
