As the saga of the 1450 oil leak turns... I'm ready to reassemble. So, regarding the valve cover/breather and carb gaskets - do I put anything on them? Soak them? Do anything other than put them into place and bolt down what sits against them?
Thanks, -Calvin |
Fuel delivery gaskets? no.
As far as the valve cover gaskets go, I've had no leaks installing them dry. |
It's probably not the "proper" thing to do, but I skin coated all the gaskets for my valve cover/breather with permatex gasket light blue stuff. All except the one that mated to the block. That way, hopefully it will all stick together if I need to adjust the valves, but it won't stick to the block. My luck the only gasket that will stick is the one that's nearest the block...
Carb gaskets, put them on dry.
--------------------- Jim in Lafayette, CO Cub Cadet 122, 126 |
A trick we use on the race car, is chapstick on the carb gaskets. It allows you to reuse the gaskets over, and over as long as you do not over tighten them.
Jeff
782 w/Honda power 129 stock for now... 100 basketcase |
