Old 12-07-2014, 09:32 PM
RedHawCadet RedHawCadet is offline
Great idea! Nice job
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 12-07-2014, 11:56 PM
Berwil's Avatar
Berwil Berwil is offline
Simple and very effective, great idea! I see this post being reference for the next guy that asks.
Bill
Old 12-08-2014, 05:50 PM
RLause's Avatar
RLause RLause is offline
I've used an angle grinder with a thin wheel and cut a screw driver slot in the end if it sticks up high enough.
Richard
Old 12-08-2014, 07:31 PM
Good idea, if it works.
Old 12-09-2014, 08:25 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
That was very smart.
I am always impressed on the various ways people can fix something with what they have on hand.
Versus a special tool commercially made only for that one purpose.
Old 07-01-2015, 07:39 AM
1250LC's Avatar
1250LC 1250LC is offline
drill it out and use an easy out BTDT
Hint....drill a tiny hole first till you hit the top of the rod,then drill the bigger hole.Then fill that with PB blaster and let it soak.
Just wanted to add that an easy out worked for me on my 1250. Maybe I got lucky. I was able to unscrew the broken button recessed in the handle with no other work needed. If it hadn't come out this way I would have cut the end off the rod and pushed the whole thing out the top. Then would replace the rod as well as the button.
This is one heck of a design. I have the factory service manual for the tractor but there is no mention of the lift handle. I was able to figure it out from an exploded diagram on a parts site and searching posts on CC forums.
