I've been reading the 1250 upgrade thread and have a few questions of my own. I had tight spots in the steering column after I changed the adjusting screw and figured the worm gear was worn so I purchased a column out of a 1050 which is a ccc 703-1085. It seems to me this one is built better than the one I took out which has Ross-10200 7 stamped on it. The 1085 has a solid shaft and a larger adjuster. What I want to know is was the Ross one the correct column for the 1650 or a replacement from something else?
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
As far as I know all the steering columns of this style are built by Ross.
107 with rear lift 1250 hyd lift. 682 diesel project Original project #2 and tiller #2 trailer 59M sheader home made boxblade wideframe 54" snowplow |
