Old 10-31-2014, 06:59 PM
JLM78 JLM78 is offline
the 1450 I got for $150 with snow blower I am in south center Michigan
Old 10-31-2014, 10:09 PM
binderfever binderfever is offline
A 1450 was my first Cub Cadet and I love it. Plenty of power for the 50" deck and good handling all around tractor. Some elbow grease and a few dollars and you'll have a good machine.
782D, 1450, 100, SO 76, 60, 102 puller, 3314 self propelled and 3323 push w electric start
Old 10-31-2014, 10:19 PM
Or if you want to part it out i would buy the rearend pump, lines lift cylinder spool valve and lever??? Or how much would you want for the whole thing, IF you decided to part with it???
Old 11-01-2014, 08:47 AM
boyesreef boyesreef is offline
2030660U560195*
according to some charts ive seen it puts it at a build date somewhere around July of '75.
Old 11-01-2014, 08:52 AM
im in the milford, novi area.
as for selling it, thats the overall plan as of now. i want to give it a chance to live again before i cut it apart though. as for pricing i havent a clue what they are worth, im a gravely guy, i know gravely prices. i might get it running and use it as a tractor show runner being a quiet line it may be quieter than a gravely and not disturb as many kids
Old 11-01-2014, 09:20 AM
http://www.oreillyauto.com/site/c/de...keyword=+k5252
can these be used as ISO mounts? they are the same as the MOOG ones ive seen being used in place of the factory. and they are quite a bit cheaper than factory too. i dont want to put a lot of money into it until i know it runs, and i dont want to destroy anything because the engines loose.
Old 11-01-2014, 10:06 AM
Greetings from the Livonia area.
Old 11-01-2014, 10:11 AM
Jeff in PA makes solid mounts, 9th pic down in this link.
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Old 11-01-2014, 11:21 AM
jimbob200521's Avatar
I second what Sam said. I had a 1250 earlier this year and decided to give the cheaper mounts a try. I, personally, did not like them. If I ever get a Quietline again, I am for sure going with Jeff's solid mounts linked above. Quality stuff from a good guy
-Ryan
Old 11-04-2014, 11:32 AM
im going to see if this tractor will start here soon. i want to know if it will run before i put too much into it. now, some if not all of the engine mount bolts are gone, you can slide the engine around with no effort. is there a grounding cable for the engine, or does it use these bolts as an engine ground? i had an old rubber mounted honda that had a grounding cable that rusted off and it grounded through the throttle cable and welded it together on the next hit of the key. i dont want that issue. the oil is clean and full. ive got to see if its got compression. looking in the spark plug hole i know the valves move. it was dark in there so i didnt see the piston, but i got my trusty flashlight some new batteries. ill run it with some carb/choke cleaner so i dont have to pull the carb and clean it to run. ill do that when i know it runs. if i get it running i may decide to keep it, see if it fights with my gravelys. so far it has one flat tire, the gravely might cause more with some yellow moving in...
