Old 09-30-2014, 02:15 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Default Need help trying to identify an old dealer sticker.
On my daughters Original it has a dealer sticker on it and it's hard to read. I'm trying to find out what dealer it is from and it's location. Can anyone id this dealer sticker? Mabe your tractor has the same sticker? Mabe someone recognizes it? Here is a pic, it's not in the greatest shape. Thanks.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 09-30-2014, 02:37 PM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
Hmmm? Hudson implements? Bout all I can almost make out.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-30-2014, 02:54 PM
Steve149's Avatar
Steve149 Steve149 is offline
You know I have found sometimes if you get it someplace dark and shine a flashlight at an angle across it you can actually read the lettering. Saw that on CSI Miami...but it does work!
Old 09-30-2014, 03:45 PM
I once saw someone use brake fluid ( not brake cleaner )on a rag to remove paint from a decal without it hurting the decal, can guarantee it will work is this case but if all else fails it might be worth a try.
Old 09-30-2014, 05:21 PM
I've used the aircraft strip spray from advance on my engine ID tags that were sprayed over by someone and it bubbles fast, if you get it off as soon as it bubbles you can save it
Old 09-30-2014, 05:28 PM
Berwil's Avatar
Berwil Berwil is offline
I think my water heater has that same "for service call" sticker. I'll go check and report back the dealer.
Bill
