Old 09-21-2014, 10:22 PM
garnold's Avatar
garnold garnold is offline
Default Fly wheel drive cub assembly on 108
Where one of the bolts go that hold on the driver is stripped. Gonna look into a helicoil to make the repair. If I need to replace this, how does it come off? I checked the service manual and didn't see it in there. If it is could you give me the page?
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 09-21-2014, 10:26 PM
Gene,
there is a nut that holds it on to the flywheel/crankshaft.
Remove the nut and it should come off.
When installing,see the manual for the torque specs
Old 09-21-2014, 10:35 PM
garnold's Avatar
Gene,
Ok I'll look at that again. Must have missed it, thought there was something else in there.
73 WIP
75 WIP
Old 09-21-2014, 11:35 PM
A 15/16"- 1/2" drive shallow socket fits perfectly.
Old 09-22-2014, 10:17 AM
garnold's Avatar
Thank you Sam. I should be able to re-coil it with it on but just in case I wanted to know what I should do.
73 WIP
75 WIP
