Old 09-17-2014, 09:41 PM
FYN409 FYN409 is offline
Default Original 3rd gear issue
So got my original running for the first time the other day. Took it for a ride around the yard and noticed it will occasionally "fall out" of 3rd gear. Any thought of what could be causing this and the potential fix?
Thanks,
Ryan
Cub Original (1961)
Cub 126 in the process of restoration.
Cub 127
1968 Minneapolis Moline Jetstar 3 w/loader
1965 Minneapolis Moline G1000
1952 Ford 8N w/Loader
1942 Farmall M
1936 Farmall F-12
1931 Rumely 6A
1929 30/50 Rumely Oil Pull
Old 09-17-2014, 09:56 PM
More than likely the detent is wore out. Could be problem with the shifter, or a bent shift fork, or even a bad gear. You will have to take the top off of the trans to diagnose.
Old 09-17-2014, 10:01 PM
There was a similar issue discussed recently, some good information here. http://www.onlycubcadets.net/forum/s...highlight=gear
Tags
gear, original, shift
