Old 09-09-2014, 12:21 PM
Dave_With_Cub108 Dave_With_Cub108 is offline
Default Cub 108 Brake Caliper Assembly
Cub Enthusiasts:
I have a Cub 108 and am replacing the brake pads. The Cub 108 serial number that I have is
2050043U 479325. There seems to be three different types of brake caliper assemblies for the 108. When I look at the brake diagrams the brake caliper assembly that is on my 108 matches the Ausco, clamshell type.
When I took the brakes apart there were no springs or spacers within the brake calipers.
The diagram also shows no springs or spacers within the brake pad cartridge. I noticed that the other brake assemblies show a “spacer and spring”.
When I tighten the bolts on clamshell caliper assembly, the pads are forced onto the brake disk so that it cannot spin freely.
I cut four, ½” springs that fit around the bolts and I left the bolts slightly loose. This seems to work and the foot brake, brake lever can pivot and apply pressure to the pads. However, the clamshell brake assembly is not tight in that it can be moved back and forth by hand.
Is this the way that the brake assembly should work on this type of brake caliper assembly?
Old 09-09-2014, 01:10 PM
I'm pretty sure the bolts for that type of caliper are a shoulder bolt, when the nuts are tightened they hold the bolt firm in the caliper but do not squeeze the pads together.
I can't remember for sure what size they are, some aftermarket lawn mower wheel bolts are adjustable, I don't know if they would work for you or not.
Old 09-09-2014, 02:26 PM
sawdustdad's Avatar
Y. Sam, (Mark?) I think you are correct on the shoulder bolts, both of my 108s (actually the 108 and the 148R which started out as a 108) have shoulder bolts on the calipers. No springs or spacers.
Old 09-09-2014, 02:48 PM
YUP.....that is what the Parts Manual says..
Old 09-10-2014, 10:30 AM
Thank you for the instructions on the Cub 108 brake caliper assembly. As you say, I should use the shoulder bolts that are designed for the caliper. Where I went wrong is when I replaced the original should bolts with the incorrect type. I did this thinking that the original bolt nuts were worn.
Now, I know what to do to complete the brake pad replacement.
Thanks again!
