Old 09-09-2014, 09:23 AM
BFH is the way I would do it.
Up to 534 and counting...
Old 09-09-2014, 09:26 AM
Steve149's Avatar
Steve149 Steve149 is offline
I have just the one in mind for the task! if the weather holds up today I may get to it
Old 09-09-2014, 10:40 AM
kostendorf's Avatar
Its not that hard, I just straightened one with two pieces of steel and a vice. The only reason I used two pieces of steel was to keep from putting vice marks on it.
Old 09-09-2014, 08:41 PM
I would use the BFH and be done with. I seriously doubt you would change the geometry of the assembly.
Originally Posted by Steve149 View Post
That maybe the easiest. looking at it once I get it straight I may opt to weld a stiffener across it if doesn't interfere with the spring or adj. bolts.
Use the BFH and the stiffener isn't needed unless you regularly run into stationary objects
Old 09-10-2014, 11:11 AM
Steve149's Avatar
Not planning on running into anything, but I did get it straight, however, the neighbor lady thought I was nuts beating on it last nite! I guess it was my colorful use of adjectives that gave her a reason for concern!
Old 09-10-2014, 11:15 AM
That is part of using a BFH.....!!!!
Old 09-10-2014, 11:18 AM
Steve149's Avatar
AMEN to that!!!! And a couple cold brews added to the effect as well LOL!!!
Old 09-10-2014, 08:24 PM
So the Universal Adjective was used a few times
Old 09-11-2014, 08:19 AM
Steve149's Avatar
Absolutely!!!!!!
