Old 09-08-2014, 10:29 PM
Default Hydro noise
i know alot about gear drive cubs but very little about hydro tractors. i have a 149 im gonna sell but it whines. the trans functions great but its loud and i guess my question is a what makes the hydro rear ends whine and how do i fix it? im plan to do a new filter and fluid but wondered how much it will help with the noise? thanks
Old 09-08-2014, 11:03 PM
TheSaturnV's Avatar
It's relative. They will begin to get noisey when fluid levels get low...kind of handy if you've forgotten to check. I'd be surprised if it didn't quiet down some after you service it. My 882 (MTD rear) has worked like a champ for years with a pretty audible whine.
HTH
Old 09-08-2014, 11:07 PM
Hydros are usually pretty quiet in neutral, if the linkage is out of adjustment they will whine a lot because the transmission is "trying to work".
They do whine some while they are moving, but normally more when the load becomes greater, like when going uphill and the lever is not moved to compensate for the extra load or when the lever is moved abruptly until the trans has sped up to "balance" the flow of fluid.
While setting still, try moving the lever a very little bit forward and/or reverse to see if the noise lessens or goes away.
Often times when the engine is shut down the F/R lever will move a little forward or reverse and cause the trans to whine.
If the filter is pretty clogged, I would imagine the trans will whine quite a bit, but I have never experienced this myself.
Changing the fluid and filter can only help.
And yes, if the fluid is low they will also whine a lot.
Good luck.
Old 09-08-2014, 11:36 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Mark made some good points. If it's noisier with the brake on, neutral needs adjusted. If not, it's air being pulled in from a low pressure side leak or cavitation.
ALL hydraulics make some noise. I'd rather have a noisy one than one makes no noise.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 09-09-2014, 08:43 AM
My 782 whines even after a oil filter and oil change.
Up to 534 and counting...
Old 09-09-2014, 08:49 PM
Thanks for the info guys, hopefully I will get the filter and fluid change this weekend and see if that helps.
Old 09-09-2014, 09:51 PM
Hydro's are noisy. If you can post a vid so we could hear it it would be helpful. Probably fine though. I wouldn't worry too much.
