Old 08-31-2014, 11:20 AM
Shaner Shaner is offline
Default Magnum 18, fuel in crankcase
I have a magnum 18 I put in my 782 to replace the kt17. I had a problem with the mechanical fuel pump on the kt17 filling the crankcase full of fuel. I removed the mechanical fuel pump and used the nipple that attaches to it to use a vacuum style pump which has worked well. I used the carb and intake manifold off the kt17 on this m18 but now I got a crankcase full of fuel again. I rebuilt the carburetor twice, set my float level as to how Matt G did in his tutorial but it still floods the block. I tried using two different floats, bought a new needle and seat but still dumps it into the block. I can't use the walbro carb and intake manifold because the choke levers actuate backwards than the kt17 carter carb.
Does anyone have any insight on what I might be missing? I'd really love to get this tractor back to service.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 08-31-2014, 11:48 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Are you sure the vacuum fuel pump didn't take a dump and is putting fuel in the crankcase through the vacuum line?
Old 08-31-2014, 08:54 PM
I had to install a manual fuel shut off valve on my KT17 to keep that from happening.
Old 08-31-2014, 10:24 PM
ford4150's Avatar
ford4150 ford4150 is offline
Put the floats in a container of water and see if they float. I know you tried two different floats, but stuff happens.
Old 09-01-2014, 12:16 PM
timbo2's Avatar
timbo2 timbo2 is offline
My 1872 did that. I bypassed the pump and went gravity feed with a shutoff valve. I also rebuilt the carb (leaky float) but I wanted to get it in running mode. Eventually I will leave the shutoff valve open and monitor the oil. If that does the trick I'll reattach the pump and monitor again.
Goodluck
- Tim
Old 11-05-2014, 04:03 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I'm late to this topic but I have had the same problem with 2 different CV single engines. I got a green tractor off craigslist this week that had a mechanical fuel pump and a crankcase full of gas. I hooked an old fuel pressure gauge to the pump outlet and ran the engine of a gravity feed tank and got a little over 3 psi of fuel pressure. What little I could find on the web says .5 to 2 psi and that more than that can overpower the float needle. I can't find any reference to rebuild or adjustment of these pumps.
Cannon
Old 11-05-2014, 09:42 AM
Group_44's Avatar
Group_44 Group_44 is offline
With what the ethanol in the gasoline is doing to all the rubber elsewhere in the fuel system it wouldn't surprise me if the problem isn't traced back to rubber diaphragm in the pump or the rubber tip on the float needle being eaten up. So much of the material that was OK before the introduction of ethanol is turning to mush now the alcohol concentration is hovering around 10%.
Old 11-05-2014, 01:15 PM
Cannon
SO....... what's your question? 3PSI is fine. If you have fuel in the crankcase, either the carb is leaking or the pump. Rebuild the carb, replace the pump. Problem solved.
Old 11-05-2014, 02:53 PM
Cannon51's Avatar
I assumed 3 psi was to much based on what I had read elsewhere.
Cannon
Old 11-05-2014, 02:55 PM
Cannon
No, it's fine. It takes at least 8PSI to overcome the float. If not more.... IF the float is set right, and the needle valve is good.
