Old 08-21-2014, 02:06 PM
RicochetFord RicochetFord is offline
Default 109 throttle cable
I am trying to figure out if there is anything that holds the throttle cable down by the carb.
When I move the throttle control on th dash the both the wire part and the outside cover move instead of just the wire.
PO had a piece of baling wire tied to the cable back next to the tower to solve this problem but I don't like that solution. I can't see we're anything is missing and the other end is connect to the throttle cable assembly correctly.
I found a random picture online that shows a retainer coming off the back of the air filter. Is that correct? The picture didn't have a description to identify what machine it was but it looked pretty close. Any help would be appreciated
Old 08-21-2014, 02:18 PM
According to the Parts Manual, you need KH-210149 Clip.
I would think you can get this at any local Small Engine Repair shop, auto parts, or Hardware stores.
This is the link to the service manual from our tech library.
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
The pic is from the manual.
Old 08-21-2014, 02:26 PM
Yes, there should be a bracket with a retaining clip that holds it in place. Check the parts book for your machine, you will see it up around the carb in the blow-out for the engine. Can't really tell much in the pic, but they are the same on all the engines. Find a parts machine and rob one. Or, they are still available new, just pricey for what they are. Like $5 or $6.
Old 08-21-2014, 02:31 PM
I think you are correct. I was thinking of the one that the choke cable used....
Old 08-21-2014, 03:30 PM
like a dis one and the one circled.
Old 08-21-2014, 03:49 PM
Thank you gentlemen, I did see that piece in the exploded parts diagram but couldn't really tell for sure if that's what I needed.
