Howdy,
I am mid restoration on a '74 Cub 1450. As I tore it apart and and got everything cleaned up, Ii noticed I tore off a lot of rubber trim, mainly around the front grill area. It's almost like cheap weather seal going between metal and metal. My question is, for those who have restored Quietlines, have any of you tried to replace this stuff? Is this even original or a PO add? Can I just bolt this thing back together without the stuff? Thank you in advance ! |
Didn't do a restore, but tore my 1650 apart when I got it and there was nothing in between the metal, come to think of it my parts 1250 had nothing either.
I'm thinking the po put something there to lesson the rattling.
Never had a quietline with anything other then the rubber on the firewall
Got a pic of what out are talking about?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
I don't remember anything like you describe on any of my QLs.
Original, 109, a pair of 122s, 124 with power lift, 124 with creeper, 126, 147, 1050, 1200, two 1250s, 1450 Dual Stick , another 1450, two 1650s, Gannon Earthcavator, Haban sickle bar and a bunch of other things you either pull, push or hang underneath. |
Need pictures.......
I Think Dave kirk sells foam trim for QL hoods
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
The only thing black by the grill is the decal between the upper grill and Lower grill and the rubber around the headlight. Then like others have said the rubber around the firewall or the bump stops by the top of the tower.
well, i dont have bpictures, and its already torn off. Must have been a PO mod. He probably could have just mounted the engine with 4 bolts instead of 2 and it would have had the same effect...
4 bolts instead of 2 ??? The PO only had two bolts holding the engine on the cradle?
| Tags |
| 1250, 1450, 1650, quietline |
