Go Back   Only Cub Cadets > Resources > Technical Library - Tractors > Technical Tips
Closed Thread
Old 08-07-2014, 08:23 AM
Default Test Light Jig
Here is an effective 12V Test Light Jig for testing continuity on switch contacts and connections, which will place a 3 Amp load on what is being tested. You can connect to a battery with bolts or alligator clips. Bear in mind, the battery has to be fully charged. Disregarding the battery, one can make this jig for around $10.00.
Closed Thread
