Hello, new here. Last year I purchased what I was told to be a 1980 IH CC 782. I mainly bought the machine because todays equipment is lite duty and doesn't last very long. Besides, I really like the nostalgic aspect. Anyway, it wasn't until recently that I found this site and really began to get the bug for everything Cub. Having said that, can someone help me truly identify my tractor based on the model and serial no?
Model No.: 143782399 Serial No.: 2050601U721976 Many thanks, Michael |
Well you're not going to like what i have to say, but what you have is a 1983 Cub Cadet Corporation(MTD) built 782. It did leave the factory red though.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
I just noticed that it has a sleeve hitch on it, and those are not recommended on the aluminum rear ends. It can be too much stress on the aluminum housing and it can pull the bolts out. Extreme motorworks makes a different lower bracket for the aluminum rear ends that have "ears" that bolt to the axle tubes, making it much stonger. The factory option was a true cat 0 3pt for it. Extreme makes those for it too.
AJ
texfire75 it happens a lot. People see the IH on it and assume it is an IH built machine. There is a local guy that swears that his is a '80 also but serial numbers out to be a '84. It's not really a "bad" thing, just do what AJ suggested and get a lower mount from extreme motor works (listed in the parts source section) and you should be OK for using the sleeve hitch.
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever! ![]() |
Oh, one more thing, make sure you check the bolts that hold the rearend to the frame. The aluminum rear end tractors are notorius for those bolts to become loose and breaking off or destroying the housing. The only complaint about the aluminum rear ends are the weight. They are over 40# lighter than the cast iron ones.
AJ
Well that blows but thanks for the help nonetheless. I don't think I'll get rid of it on that account as it is a good strong tractor. I paid $700 for it in good mowing running condition so I guess it is what it is. If I were to sell it though I now know NOT to present it.
Just out of curiousity, are there any major differences between the MTD CC and IH CC? I have been doing a lot of digging around on here and I'm somewhat of an implement nut. I saw an adaption by I believe Georg from Germany? Anyway, I took some inspiration and designed a similar bracket. I work in the mechanical engineering field and use 3D modeling software every day. I also have access to a full blown fab shop and we are in the process of fabbing up the bracket shown in the pictures below. Thanks again for the help. Michael |
Your dash reads differently and the aluminum case is the difference. You also have the advantage of the KT17II and not the SeriesI.
Both the trans and dash can be swapped and cheaply I might add. I have a CCC 982 completely factory and built completely of IH parts, they are marked so, from the CI trans to the exhaust cans. Why is mine of lesser value than another??????? (rhetorical) Scott |
This evening I started the install of the side plates for the adjustable bracket. In order to install the bolts from the inside of the frame, I had to remove the bolt that holds the lift bar to the sleeve hitch. When I took the bolt out, the bar slid right out. Upon inspection, I found the the end of the bar/rod was broken on the end and not attached to anything. Now I have to figure out where that was attached. Anyone know. I'll upload some pictures tomorrow when I get to work.
Actually with that serial number, it would have left the factory with a Series 1 engine. 726125 would have been the first tractor wit hthe Series 2 engine. So Textfire, I would check you engine to make sure which one you have. It it's a series 1, the spec number will be below 24300. If it's a series 2, then the spec number is 24300 or higher. if you do still ahve the series 1 motor, becareful to not get it one a hill side. The rod journals are splash lubed and it will throw a rod. The series 2 engines, added the pressure lube to the rod journals.
AJ
![]() Quote:
![]() Nice looking 782 you have there! |
