Old 05-20-2014, 10:08 AM
Yes, you should be able to adjust the location of neutral from the bracket on the transmission, it's not very hard to do.
My best guess regarding the vibration issue is, something in the drive shaft, it could be any of a number of things, as mentioned before, check the flex coupler, the drive hub that bolts to the engine and check the drive shaft to make sure it isn't bent.
Old 05-21-2014, 05:19 PM
Mossmanxjt Mossmanxjt is offline
I found the vibration problem. The driveshaft is either bent or off-center at the rag joint end. There is a driveline shop down the street from me that can probably straighten it. What is the best way to get the shaft out? Can it be done without splitting the tractor?
Thanks,
Mike
Old 05-21-2014, 06:17 PM
I have the same problem with my 123. What threw me off was that it just started after I rebuilt my 301 and put it back in. I thought that if the shaft lived for so long being in the motor one way and now it's 180 off, maybe that's doing it. But, I can see the shaft wobbling quite a bit so I must have tweaked it a little during r and r of the motor or something. Bums me out but good to see you found yours though. And yeah, unfortunately you're going to have to split it. Not a bad job to do, looks intimidating but just a few steps and it's done. Leave the rear tires on, disconnect a couple brake linkages and trans to frame bolts and roll it right out. Obviously use jack stands for safety
Old 05-21-2014, 09:09 PM
The rear drive shaft coupler is prolly worn.the driveshaft has a little tit on the end of it, it wears and so does the coupler.
Old 05-21-2014, 10:13 PM
Unbolt the engine, disconnect the pto rod and slide the engine forward. Probably have to unbolt the "tin" under the dash tower (the one the drive shaft goes through).
Old 05-21-2014, 10:40 PM
Be careful not to break your hydro fan when pulling the shaft.. They're not too terribly tough after being heat cycled for 40 years and are easy to break.
Also.. You may be better off to pull the rear out to pull the shaft since all of the linkage and stuff back there is usually worn, or out of adjustment, anyhow (and normally have hydro leaks-o-plenty). May as well kill a couple of birds with the same stone. Good chance for a nice frame wash too.
Old 05-22-2014, 02:49 PM
I found the problem. The flex coupler is oblong and had one hole ripped out. The tit on the end of the shaft was worn on one side from running offset for what looks like quite some time. The coupler has a matching wear spot. The driveshaft is straight though and the fan is not damaged. I am going to try a new flex disc and rotate the shaft so that the two worn spots don't line up anymore and see what that does. Splitting the tractor was pretty easy so if this doesn't work I will order a coupler and replace it too. I could probably have the tit on the shaft welded and ground to fill in the worn spot if I have to.
Old 05-22-2014, 10:23 PM
The tractor is back together and the vibration and driveline wobble is gone. I put in a new flex disc and used some JB weld to fill in the divot in the coupler and re form the tit at the end of the driveshaft where it was worn away. After it was cured I filed everything back to what it should have been pre-wear. I figured the JB fix would be worth a shot before I ordered a new coupler and driveshaft.
Old 05-22-2014, 10:38 PM
I make driveshafts
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
post 9
Jeff
Old 05-22-2014, 11:26 PM
Jeff I checked mine tonight and the coupler on the opposite side of the flex coupler is what is loose, roll pin hole is ovaled out bad and whole thing wobbles on input shaft of hydro. Do you make the other piece that I'm talking about? Same model as OP, 123.
