Old 05-22-2014, 05:28 PM
peterjt408 peterjt408 is offline
Default 129 drive plate hub assembly
I need to replace a worn drive plate hub assembly (IH-394034-R31/32) on a 129. After removing the drive rod, do the 4 cap screws that secure the hub assembly also secure the pulley (& anything else) behind the hub, or do they only secure the hub? Any difficulties I need to be aware of?
Old 05-22-2014, 08:02 PM
Should be a nut on the end of the crank shaft that holds the hub on.
Old 05-22-2014, 10:50 PM
OffTime's Avatar
OffTime OffTime is offline
Just a suggestion. The drive arrangement on those mowers was not the best arrangement in the world. If I were you, I would upgrade to a Quietline drive shaft arrangement. I think it will bolt right in, but the entire shaft must be replaced to do that.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 05-22-2014, 10:55 PM
The four 1/4" cap screws do indeed secure the drive plate to the hub. Not to worry, take 'em out, a little light tapping may be req'd and it should come right off.
What if anything is wrong with the drive hub and/or pulley?
Old 05-22-2014, 11:32 PM
sawdustdad's Avatar
Here's what an upgraded drive assembly looks like. This is a 149 (should be similar to your 129) with a quiet line drive arrangement. Uses the same 4 small cap screws to secure the drive bracket to the hub, and you will need to buy the drive hub and the extra drive collar that you pin to the existing drive shaft. Add the flex coupling and the necessary bolts.
Old 05-23-2014, 08:34 AM
The hub has 1/4 inch long grooves created by the metal pin.
Old 05-23-2014, 08:50 AM
Copy that! Anyway, that's how it comes off. Repair or replace as necessary!
Should not be too hard to find a replacement. The rag joint solution is a good idea also.
Good Luck!
Just went through the same thing with my 149.
http://www.onlycubcadets.net/forum/s...t=31416&page=4
Scroll down to post # 66
