Old 04-06-2014, 12:37 AM
Well, I'd say the carb bowl is running dry. It backfires as the fuel mix goes lean. Pull the carb and fuel tank. Clean them, install new fuel lines and try again.
Old 04-06-2014, 12:41 AM
cdrookie cdrookie is offline
carb bowl has gas in it, fuel line has good gas flow, good flow out of needle/seat into bowl, float is set correctly.
Old 04-06-2014, 02:05 AM
Something is plugged. Or the tank doesn't vent well. Look it over again, I think your missing it. Did you make your own air breather gasket? Maybe you blocked the vent to the carb bowl?
Old 04-06-2014, 11:27 AM
made the gasket from carb to motor, since the old one was half missing. tank vent is fine. guess i will grab new points/condenser and see if that does anything, coil to.
Old 04-06-2014, 12:00 PM
kostendorf's Avatar
If your going to change all those parts, check Dave Kirks site out for a points saver kit. It makes it a lot easier to time too.
http://www.kirkengines.com/
Old 04-06-2014, 12:20 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
gas tank cap is the vented type with a hole in the center?
Old 04-06-2014, 12:23 PM
Defective condenser. BTDT
Old 05-22-2014, 08:58 AM
little update:
got another carb off ebay, and after messing around, it made no difference.
cleaned all the crap off of where the condenser/coil mount and it ran a little better.
new head gasket = little better
new points/condensor, and it actually will make it up my driveway in 2nd gear(about 2% grade).
gonna clean the valves when i get back home.
thanks for everyone's help
Old 05-22-2014, 09:03 AM
Originally Posted by cdrookie View Post
little update:
Thanks for the update!
Old 05-22-2014, 09:37 AM
sawdustdad's Avatar
An easy way to tell if it's starving for fuel is to pull the choke out when it starts to die, if that helps, then you know you've got a fuel problem.
